ln76d said:All three can be both type.
Cheers, I now see that it's 2 x 2 positions and 1 x 3 position.....makes sense
Was your diode installed correctly?Lordward said:Anyone? :-X
This will work but it's a bit overkill. Any reason you are looking at this transformer?3nity said:hi guys im slowly getting into this project!
I was wondering if this transformer would work for psu!
http://www.antekinc.com/as-05t240-50va-240v-transformer/
Kraume said:So i just ordered everything and be very excited to start soon with this new project.
There is just one thing i'm wondering about: The Mouser Boom holds a 0.3A fuse. The first Page mentions 0.1A and 0.2A. What do i need in Europe using this transformer. http://www.mouser.de/Search/ProductDetail.aspx?R=FS20-300virtualkey55310000virtualkey553-FS20-300
Thx and Greets
Lars
poctop said:... i remember reading a document called the Pin 1 Problem in regard to driving different equipement on realted ground without having issue and the need of a ground lift very interesting article , i am really glad you made this point ,
shewhorn said:The components for the PSU from this BOM ****MINUS THE CASE**** $95.38:
https://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=b5c122b4d0
dmp said:If it's your first build, you might want a cheap capsule and tube to use until the mic is done
For the plate cap, try out the search function at mouser. Use the search fields to narrow it down.
Delta Sigma said:Personally I'd buy tubes from Bowie. I don't know if I trust most vacuum tube sites any more than Ebay. Not that they're trying to pull a fast one it's just that they're targeted toward Hi-fi and guitar amps, not microphones.
Before I knew about Bowie I bought my EF86 here but they're sold out of the Silver Hilumen.
Hi Dennis, I also had the same problem , Even if it does not burn the diode , 22 VAC in the heater line is too high when you dont load the PSU, and the diode can burn. In Spain the line can vary from 205 Volts to 235, this cause a lots of problems in this kind of regulation. Dan told me : Please no more than 20 vac in the heater!!, and it works perfectly. When the line is near 220vac, No problem without load, whem rise a little the temperature in the zener is critical. Hope this help.Lordward said:Still hoping for a bit of help here. I've complete my build and I'm having some issues at calibration.
For a start I measured the PSU, mic not connected, and I get the following values:
Heater = 22VAC
AC In 210 = 270VAC
B+ = 227 DC
H- = -17.77
Mic plugged in, no tube:
B+ = 249
H- = -17.66
0.9 Ohm between the mic body and the chassis of the PSU
Right after measuring my PSU gave out. It kept blowing fuses and the last fuse I put in I could smell a bit of electrical burn.
I took out the PCB and could see that D1, the 15 V 5W Zener diode has burnt out.
What could the reason for this be?
Dennis
shewhorn said:I'm in the process of doing all of the research for this build. I have some issues with reading so... parsing a 59 page thread is a little daunting. I'm wondering if anyone who has recently done this build can help me out? Here's my understanding of what I need:
All 5 items from the PCB-D-67 kit from this page $89:
http://www.vintagemicrophonepcbkit.com/orders.html
This mic body kit from Studio 939 (SYT-5 Gen 3) $145:
http://store.studio939.com/product/syt-5-microphone-body-kit
The components for the microphone from this BOM $45.05:
https://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=83ad963d23
Now, here's the first problem, the Vishay 0.47uF cap is obsolete. None of the equivalent options are in the same package. What is everyone using for that? I've narrowed the field down in the following link. Looks like the Wima and the Nichicon caps are the closest matches but neither are the same form as the Vishay. Will they work in this build? The Wima doesn't even have bendable leads... could solder some leads to it but... still, tight spaces etc. What is everyone else doing?
http://www.mouser.com/Passive-Components/Capacitors/Film-Capacitors/_/N-9x371Zscv7?P=1ywtgmbZ1yznbzsZ1z0wquaZ1yzs9nv&FS=True
This case from Collective Cases $65:
http://collectivecases.com/?product=psu-cases
An HK67 Capsule from Heiserman Audio $250:
http://www.heisermanaudio.com/store/p4/Heiserman_HK67_Capsule.html
AMI T67 Transformer from Zen Pro Audio $110:
http://www.zenproaudio.com/tab-funkenwerk-ami-t67-transformer
Amerpex EF86 Tube $99.95:
https://tubedepot.com/products/amperex-ef86-6267
Total cost: $899.37 (plus some shipping charges I'm sure)
Is there anything I'm missing?
Yup, as long as the capacitance is the same, the 'science' is trying to even hear a difference. You can do null tests to isolate what is different if you really want to dig into it. If you are comparing different types of caps you're more likely to notice something, i.e. film to PIO. Blind tests are good when doing this sort of thing.shewhorn said:Is there any science behind determining which of those would sound the best or does it come down to trying it in the circuit and hearing how it sounds?
