Hello,burglar said:Hi folks,
Planning on building two of these soon. What power supply are most using for a dual mono unit? If there is not a preferred kit would someone mind posting a schematic??
Many thanks
B
burglar said:Thanks Udo,
Forgive my newbism, but I need + - 15vdc for both boards. If my PSU has + - 15vdc how do I supply it to both channels of the EQ?
No,they will become scratchy soon.jicama said:Hello guys I'm very confused at the at the shopping list of this project says 8 pots 10k linear dual, but now I'm reading only 2 needs to be dual!
And I know has to be conductive plastic does anyone knows if carbon type can work I have this pots
http://www.mouser.com/ds/2/54/ptd90-35260.pdf
Thank you for your help
kante1603 said:No,they will become scratchy soon.jicama said:Hello guys I'm very confused at the at the shopping list of this project says 8 pots 10k linear dual, but now I'm reading only 2 needs to be dual!
Udo.
Replay? ;Djicama said:Thanks for the replay Udo,
And what about the dual pots? How come now I only need 2 dual instead 8? Will work the same?
kante1603 said:Replay? ;Djicama said:Thanks for the replay Udo,
O.K.,let's get serious.....
Only two duals are needed,you find them in the mid bands.Look at the schematics here:
https://docs.google.com/file/d/0B_XBYPfmG8pVMDkyMmRlNjEtZmQwMS00OTgwLWJkYzMtNWRmNGYyZTE1NTRm/edit?hl=en&pli=1
You can even see which ones must be dual by looking closely to their traces on the board.
The others were just dual for mechanical reasons,but not necessary.
Udo.
Udo.
