Is one W492 board mono or stereo?
Mono.
I was wondering if it is possible to use the W492 board with the following changes:
1. vertical version of the EQ, with "zero" stops on the EQ pots. This is for a dj mixer, where vertical and zero stops are essential.
Zero will not work corectly because there is none in real life conditions (due to tolerances up to 20%).
2. -25/+10 db attenuation on each of the EQ sections. What will I need to do to make this mod?
This is a different beast,so at least the -25 is not possible without completely redesigning the whole eq.
3. one board must be a stereo channel.
You need two boards for stereo and at least two 4-layer plastic conductive pots,hard to source I think.
Definetely the wrong eq for DJs.
thanks,
Herman
Udo.
