Hi guys , how goes , I'm very happy to can say , PROJECT ACHIEVED
https://youtu.be/zgp1fZA3ZVM
The power transformers are momentary solution until find the right toroid for 1 u. rack.
next thing , I gonna calibrate the detents at real 0 and test L and R frequency similarity moving knobs from pots if necessary , all checkin with SMAART ... and this goes directly to my disc cutting system chain , yes , the place where this piece go.
The POTS : The B.I. pots from capi-gear.com.....I only can say the same than mr. Steiger , "don't let the price fools you !" , because is totally true , THE FEELING OF THE POTS ARE ABSOLUTELY AWESOME , even better than tens I touched in glorious well made equipment , really sure an hard over the entire path , the find of the year for me (and .... ejem... have center detent version.... where people get the center detent version of the OMEGs ? I can't believe people have this project without center detent.)
The ICs = NOS Philips NE5532AN (That is where my powers problem start over the encapsulated transformers , reach 50º C easy!! hahah , but I'm very happy with the character , can be very very subtile , this is a thing I don't expect from a 553X based filters , and the sound are less metallic than I expected too , I'm very happy. )
- The boards from the man Gustav of pcbgrinder.com (Ough! how can I forget the foundations , noboody begins the house through the roof. )
- All resistor Metal Film 1% , checked In pairs at soldering time.
- All capacitors 2,5 % , 5% , and 10% on 2 or 3 values ( one can go until 1% in capacitors but become a not so cheap project as all people suggest , REALLY I don't think is a so so cheap project.)
- The case is a recycled adam hall housing case I never used at all , a crossover project in the past.
- The frontpanel is mechanized by frontpanel.de
- The relay bypass boards and the knobs are from diy-tubes.com
- The power supplies are classic Velleman regulable kits (LM317 /337)
*I do a little thing for the bypass , with a 2 color led (the 3 pins one) , playing a bit with the switching can go for :
-Geen light when both L and R are running
-Orange Light (both green and red poles) when 1 of the channels is bypassed
-Red Light when 2 channels are bypassed.
The B.I pots are soldered using a holes proto board I cutted in very little squares of 3 x 3 holes.
wire , thermo retractile and think is all friends!
Best Regards
Mani.
