john12ax7 said:Where are you getting the metal work and faceplates done? They look nice.
I'm wondering about the same thing?
rbuskov said:I'm wondering about the same thing?
sasarist said:I made them.
Powder coating and N fronts are not good idea.We use som hi quality industrial paints.Print is UV printrbuskov said:How? Are they powder coated or just painted? How did you do the print?5
sasarist said:Powder coating and N fronts are not good idea.We use som hi quality industrial paints.Print is UV print
Neve mate.warpie said:Excuse my ignorance but what do you mean by "N fronts"?
First is the colour problem, powder coating has very limited palette to chose from.Second is overall look , satin gray blue paint look much better to me.I spend a enormous amount of time to find right one , and at the end it turn out, that Mercedes satin paint was the best.rbuskov said:Thanks for the info.
How come?
r2d2 said:Only "as well" ….
anybody made some test ( also "virtual" ) about " THD" and signal to noise ratio
for a classic 16 or 24 ch to L-R master bus ?
cheers
PS :
just to avoid unpleasant sound surprises….
(after so lot of work…. and money too..)
remsouille said:Well we're doing everything by the Great Neve Book, so I guess THD and SNR should be pretty good Not trying to reinvent the wheel, here !
Actually , I test modules and they sound beyond my expectations.My biggest concern were our custom inductors , but it tourn out that they "affect" sound in a same way as geniune, one which are wound on smaler core.r2d2 said:The project is so Extremely "porn"…..
if it sound as the original (...as expected) , is 10X Extremely "porn"
cheers
mjrippe said:That is dead sexy! And I like your taste in furniture as well ;D
Rob Flinn said:I'm interested to know about the output transformers it appears you have wound. I am looking at the split bobbin, is one side secondary & the other primary ? Looking at CJ's winding docs for the 1166 it appears that there are 2 primary layers & 3 secondaries.
See here
https://img1.wsimg.com/blobby/go/0e07cc59-2f5a-481f-967d-12c7363b86fa/downloads/1ctuvlm4f_626108.png?ver=1559636350707
