[quote author="mtw"]Greetings,
I am slogging my way through an order with Mouser, working off of DJD's 33609 BoM. I'm looking up part numbers for capacitors and, having only one DIY project under my belt, am trying to navigate the byzantine maze of capacitors. :shock:
I'm looking for a suitable part for CJ2, a 33p silver mica cap. Is this
"Mica Radial Lead Capacitors 33pF 300V +/-2%" suitable?
Also, how about
this part for C19, C20, C21 - 100p silver mica caps.
Thanks in advance!
-mtw[/quote]
Hey if you are going off of my BOM, there are some errors. I'll try to correct and re-upload, but for starters you do want ON-ON switches. I ended up using some from Mountain. It's a minor quibble, but the finish is definitely not as nice on the Mountain switches as it is on the C&Ks.
I also would double check the specs on the 470uf 25v electros. I had KZs listed, but they are pretty big for C15,C16 and C18. Some of the resistor values are not available in the Xicon brand. I just went down the line with the Mouser part number substituting the correct value, but it didn't always work... Lastly, double check the leads on the WIMAs I have listed. They work, but you'll have to do some lead tweaking...
When I ordered my parts, I double checked the quantities against Richard's BOM - it would be smart to do the same.
Best of luck (and sorry for all the caveats...)
JdJ V5 BOM
J
