Hi!
Thanks for asking Igor, yes I changed them, but I’m sorry to say that there’s still no audio going through my PCBs. same on both pcbs. I have a feeling that the error is on the 340 boards, but I haven’t been able to spot it yet.
Just check out what happens on secondary of input trafo, then on
tp_a, tp_b, tp_c.
If on tp_c you get approx. 25 db lower sin wave than on input,
then check twice ba340.
All the Voltages on mainPCB, from your voltages-schems are spot on correct. And I have been changing most of the transistors, just to be sure.I've also randomly checked most of the resistors. so voltage-vise, things seems quite ok.
Feels better
When I turn it on, the meters go to the top, and then after a minute it turns to zero. So there’s definitively a strong power-signal going to the meters in the beginning there.
This is OK, let the unit 10-15 sec to stabilize after power-on.
Does anybody have a suggestion for me to try next? Should I try an alternative to the 340’ties?
Just see what happens before ba340 on tp_c
Igor, I noticed that resistors R6 and R60 differs from the original neve schem. (R6=24K and R60=62K). But I guess you have a reason for this?
r6 is actually jumper... r6. same 24k as in orig. schemo; same with r60.
Values printed on pcb are all right.
Except:
There's one resistor on each front pcb (on comp. recovery switch)
which is 24k in one variant of orig. Neve schem and 6k8 in other...
I used older version, then...
it marked r10', located near com. recovery switch and should be 24k.
6k8 will work but recovery will be very fast on 100ms setting.
BTW: I am surprised that a popular DIY project like this has virtually no technical or troubleshooting discussions going. Where is everybody?
I trying to help as possible...see 2254/33609 tread as well.
You can pm me and I'll try to help you using Skype in my free minute.
