Anyway, I'm not the one that should be telling you this. My 33609 don't work! Looking at the scope, my signal gets all messed up around the D18 & D19 area. The exact same thing happens on both boards.. there's definitively something I've done wrong. but what can it be?
sending the signal from the second transformer and out, everything seems fine. And the relays work fine. - There's no reaction in the signal if I turn the knobs on the front. (except the bypass)
ps : Maybe the ones that have finished their units, could post HIGH-RES guts pictures? To see finished v1.2 boards might help...
Will post hi-res pics in next hour-two.
So, if you putting signal to pri of interstage trafo it appears OK after output trafo, right?
Did you connected both lim amd comp cables going to front?
Are 4153 diodes installed right? Which type of input trafo used?
Please check twice if TR 3,4, 16, 17 installed correct.
There's 2 types of BC214, one ebc and second bce.
Check all resistors values across.
Check voltages on tr3,4 according to schem.
Try to see if there's signal on secondary of input trafo,
it is completely floated, you have to connect scope _across_ secondary.
It is easy to do on 5-pin connector near trafo.
If you feed 0db, at secondary should be -6 db.
Check waveform on TP A,B, should be -31db one in, one out of phase.
If you can post picture, will help a lot.
(edit: seems after replacing bc184l to 184c you'll get it working
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
