ruffrecords said:
I know you keep being drawn back to the 500 format and I can understand why. However, as you said yourself, the mechanics of this project is key. The problem with the 500 series is there is no mass produced , available everywhere, low cost metalwork for making the buckets. I know because I spent a lot of time trying to find it for the EZTubeMixer project. I f I had found it then the EZTube Mixer project would be 500 compatible. That's why I ended up using Eurorack sub-racks. The components are available worldwide from many manufacturers. The system uses tapped strips in extrusions to attach modules. The strips have taps on 0.2 inch centres which means you cannot make 1.5 inch 500 series compatible modules. However, you could make 1.4 inch wide modules. exactly 12 of which would fit in a rack.
I am just wondering if there is a smart way to use this system but make 1.5 inch modules. If each module had two alternative top and bottom pairs of fixing holes, for example 0.9 inches apart horizontally, then there would always be one pair that would mate with the tapped strip. Just a thought.
Ian, when I made mixers in a previous life, I used standard extrusions and chose a 40.64 mm pitch, which allowed me to make the modules out of standard L-shaped 40mm extrusion. I had the chassis made by a specialist company, and they had 3-hole tapped strips that were held in place with plastic rings, which allowed them any spacing. My choice of 40.64 allowed me to use standard strips that were about 80cm long.
40mm width allows the use of 12mm pots, even 16mm that are easier to source.
40.64 pitch would allow the use of 1.5" modules with the simple addition of a gasket...
