Sorry about that - the unsubstianted claims just looked exactly like marketing for the uninformed masses
Hi Rob,So far, the only unsubstantiated claim with regard to my project ....
Does the PSU contribute to the sound of the C800G?What surprises me is that the external C800g PSU is not worth a single word to the author.
I like the 0.22F caps in the heater voltage supply, too.
All audio devices are affected by the quality of their power supplies - their sound is literally the modulated power supply.Does the PSU contribute to the sound of the C800G?
As far as noise is concerned, it depends on the circuit topology and its ability to reject power-supply noise, expressed as power supply rejection ratio, or PSRR. In a grounded-grid amplifier, the PSRR can be approximated by the voltage divider formed by the load resistance and the anode resistance (PSRR = Load Resistance + Anode Resistance / Anode Resistance). In a cathode follower, it can be approximated by the inverse of the mu expressed in dB.Big question then is, to what extent?
Im guessing that the C800G will sound like a C800G if it had a non Sony PSU with the same specs?
Then that is why I didn't include the PSU in my Gearspace post. From all of my research online, the biggest differences between the "clones" and the original C800G, is that none of them match what the actual mic has in order to sound like it. All the articles and interviews with the engineers that designed the C800G, that were translated from Japanese, talk mostly about what make the mic sound the way it does, and very little about the PSU. I don't see why I would include the PSU comparing the "clones", when they didn't even get the microphone itself right.I don't see why it wouldn't.
Remember, these are opinions and they vary. It would be interesting to do really reliable blind tests on this topic. The power supply of the C800g is a bit different from most others. Only a real test can show whether this leads to audible (and measurable) differences, but I wouldn't rule it out completely from the start!Then that is why I didn't include the PSU in my Gearspace post. From all of my research online, the biggest differences between the "clones" and the original C800G, is that none of them match what the actual mic has in order to sound like it. All the articles and interviews with the engineers that designed the C800G, that were translated from Japanese, talk mostly about what make the mic sound the way it does, and very little about the PSU. I don't see why I would include the PSU comparing the "clones", when they didn't even get the microphone itself right.
I think there are differences between the effects of a real circuit and the stuff you're talking about here. The original article on gearslutz was very detailed, I think a closer look at the power supply would have fitted in well. If you equate that with the power quality of your energy supplier and the "time of the day the electricity is purest", I can't take you entirely seriously. Sorry.If I include the PSU, I might as well include the mic cable/shock mount/temperature of the ambient air/electric company/time of the day the electricity the electricity is purest/which part of the hemisphere you reside/atmospheric gravity
It was in jest, it wasn't meant to be taken seriously.Remember, these are opinions and they vary. It would be interesting to do really reliable blind tests on this topic. The power supply of the C800g is a bit different from most others. Only a real test can show whether this leads to audible (and measurable) differences, but I wouldn't rule it out completely from the start!
The PSU schematic is available, however, and contains everything you need to know.I would've mentioned the PSU in my post, but there wasn't much information on it from the designers.
I don't post on gearslutz anymore.If you find any information on the power supply, you can reply to the post and add the information. More information is always welcome.
Weeeeeell, i'd argue there's a pretty good chance the tube rectification for the B+ rail becomes virtually irrelevant with the 5.6k / 220uF / 8.2k / 220uF filtering in the power supply, and there's another 10uF on the B+ rail inside the mic.
Heater rail's filtered with 20mF (yes, milifarads), zener-regulated, plus 2200uF and an extra 2F with those supercapacitors.
But that's just your opinion from a distance, you haven't done a blind test on this topic yet, have you?Yeah, i'd call the power supply a non-issue...
As you know, I can read schematics as well and I can see some peculiarities in the PSU of the C800g compared to many other tube microphones.
From my point of view it would be interesting to do some comparative measurements, if you a really interested. I'm talking about technical data first, and once you're through with that, as I said, blind tests would be helpful if you really want to get to the bottom of it. (This was the claim of the original GS thread).
Otherwise these are just opinions from a distance. Volume and frequency of repetition are no substitute for real data and experience.
It is quite possible that the differences are marginal and possibly not worth the effort. Nevertheless, I would not categorically rule it out, my experiences were partly different. Power supply topologies and dimensioning play a technically important role, to what extent the sound varies is something everyone has to work out for themselves.
What the hell are you talking about? This isn't Gearslutz, we like to look at schematics of the things we're talking about, I don't need an "interview" from some "designer" to see what's going on. What kind of expertise is that when you take the marketing blah blah from some interview as the gold standard and base your statements on that? Have you ever built a microphone with a power supply? How many? Is it enough to read interviews with "designers" to be a player now?If you have an issue with the perspective of what contributing factor the PSU has, then you should take that up with the designers...or maybe the original interviewer/article writer.
That's GS style, we don't need that here. We like facts!
So, is this a theroethical debate or are we talking about building an authentic (whatever that is) C800g microphone?Please calm down. You asked why I didn't post about PSU in my gearspace post...I told you why I didn't. I couldn't find any insight on design choices by the designers. I think emotional tantrums on disagreements is what we don't need from "GS style" posts. If you have anything intellectual to contribute to the post, like a schematic or what you find on the PSU...then please post it. If not, then please lets move on like adults. I don't see the point in arguing about "why didn't you post __________?" When you can really be contributing to the conversation by posting what you see is missing.
