bernbrue
jandoste said:You're not alone... I finished the unit but it doesn't work yet ;(
So, what is wrong? It can´t be a big issue.
regards
Bernd
baadc0de said:I'm about to order a transformer, I see for the 250V volt input that there are two 3 inputs, one of which goes to the ground plane. Then the 9V input and the 24V input both have only two connections..
bernbrue said:baadc0de said:I'm about to order a transformer, I see for the 250V volt input that there are two 3 inputs, one of which goes to the ground plane. Then the 9V input and the 24V input both have only two connections..
Don´t use the middle pin of the 3pin connector for 250V. You must use pin1 and 3 for the high voltage. You don´t need a 250V centertapped secondary. I still don´t have any pcbs.
regards
Bernd
RATMNL said:CU-folienschirm gelb/grun wire, should I connect that to my star-ground, or could that be connected to that ground pin 2?
(thank god I understand German..)
EDIT: oops weren't talking to me
