Not to step on toolshedamps toes but I have some extra ones I can sell.Anybody plan to put some of these PCBs in production ? I'd be interested in a pair.
Thanks !
Thanks !
You should experiment. The only notable difference would be regarding the magnetic filed from the power transformer? Since you have an aluminium chassis, it does not provide magnetic shielding, but the flux lines are probably different. You should experiment with the orientation also. Regarding electrostatic shielding, the impedances are low enough to make it negligible.For Output Tx, do you think it'd be better to mount it opposite, inside the case, so the cables stay inside?
No.Would i need to fill the gaps?
If you made this chassis, there is no reason why you couldn't make adapter plates.I guess the best way would be to make specific adapter plates, but i'm not equiped for that,
Thanks!! I will experimentYou should experiment. The only notable difference would be regarding the magnetic filed from the power transformer? Since you have an aluminium chassis, it does not provide magnetic shielding, but the flux lines are probably different. You should experiment with the orientation also. Regarding electrostatic shielding, the impedances are low enough to make it negligible.
No.
It may or may not...Thanks!! I will experiment
Isnt it going to be an issue then that this chassis is made of aluminium?..
I bet one day you'll have to have a hacksaw and a vice.So i’ll probably use a metal bracket from hardware store because i can’t cut metal, i only can drill holes
I am in the process of building a LA2A with UTM transformers too, and I have an analogue vibe chassis... which means I'll make some adapter plates one of these days (I'll CNC them). Send me a PM and I'll see if I can make a few more. I just don't know when that will be because I have quite a lot of projects on going. But by the end of the year, for sure.Thanks!! I will experiment
I bought it as is, just made a few holes in it..
If you want to mount the unshielded output transformer on the outside of the chassis (although as stated the aluminum chassis isn't going to provide shielding anyway) I'd buy some steel transformer covers like these...... (see link below) to shield it.Hi everyone,
For a LA2A project, I plan to use both UTM (2510-In and 3515-Out), so my question is : could you suggest a better solution to mount them?
As you can see on the pictures, i "secured" the Input Tx with two aluminium plates, but there is still some gap between the transfo, the plates, the case...
I guess the best way would be to make specific adapter plates, but i'm not equiped for that, so if anyone use those Transfos for LA2A, how did you mount them?
Thanks, as always, for your inputs, great help, and have a lovely day
View attachment 98026View attachment 98027
No, this transformer is dedicated to Sansui AU70 power amp. This is a special kind of cathode negative feedback. The schematic is attached.Does anyone know if the UTM7070 has ultralinear taps on the primary winding? There doesn't seem to be a "contact" tab on the website and no further info on these transformers is in the latest catalog (2c) pdf.
Thanks! Matt.
Yes, no problem.I see you make a Low Profile version of the 3523 for 500 series module. Do you make the same for the 3503?
Ah, excellent. I will be getting the 3523's first and the 2622's.Yes, no problem.
EDITNo, this transformer is dedicated to Sansui AU70 power amp. This is a special kind of cathode negative feedback.
That........ and, it looks like the output tubes are biased strangely as well. Thanks!It's just a standard Williamson amp with the usual arrangement of NFB taken from the 16 ohm secondary.
However, it is peculiar because of the weird arrangement for the headphones output.
Fixed bias, at -18V. Nothing curious about it.it looks like the output tubes are biased strangely as well. Thanks!
Ahh, in any case, not my cup O' tea. I've designed a SE (5842) -> IT -> Pair EBL21 (UL connected), CCS bias PP amp and will be "auditioning" 8K-10K primary OT's over the winter to see what I like... the UTM7070 was one of them that I was hoping to try. I'll just PM him directly. Thanks!EDIT
Actually, the secondary is a 16ohm+16ohm, and indeed each goes to the cathode of teh output tubes, so yes, it's cathode NFB.
One again, I forgot to turn the barins on before typing.
