Is there a direct swap for a CarnhiII VTB2568? WouId be fun to buiId an AmI 1081 pre with these I expect.
Not sure at aII, but sure that is what it said on CoIin's AmI pdf for his 500 1081 pre. Was kind of hoping the UTM3548 wouId do it.I can't find a CarnhiII VTB2568 in the CarnhiII catalog, are you sure that the correct number?
As far as I as know the 1081 preamp used the Marinair LO2567 output transformer which is the Ungapped version of the LO1166.
So the current Carnhill equivalents for the LO2567 are the VTB9047 , VTB9070 (1u rack narrow board version)
UTM already makes an LO1166 type transformer, it's the utm3548 it's just the matter of making the same transformer but ungapped, with is actually easier.
https://utmindustry.com/utm3548
Thanks for the heads-up. Aound post #89 #92 we were talking about a gapped OT for SE tube circuits.I see a new offering from UTM, and it looks like a UTC clone of some sort. Anyone know anything about this one?
https://utmindustry.com/utm3590b
I hope you'll like this housing. We can use it for many transformers from our offer.Thanks for the heads-up. Aound post #89 #92 we were talking about a gapped OT for SE tube circuits.
Will try these very soon. The range is expanding quite fast.
I notice from the picture that the transformer in this enclosure uses UI laminations rather than the more common EI. Is there a reason for this?I hope you'll like this housing. We can use it for many transformers from our offer.
I'll update the catalog shortly to show you the pinout and dimensions.
It's just a comparison of the size of our smallest and the largest transformer (0547 vs 3590). The small one is not inside the big enclosureI notice from the picture that the transformer in this enclosure uses UI laminations rather than the more common EI. Is there a reason for this?
Sure, why not?They look like great value for money , can the UTM 3580 type transformer be done with the new case ?
Hmm, tasty!I hope you'll like this housing. We can use it for many transformers from our offer.
I know what you mean and of course, I checked it.How come and there's no ringing on the 9046 (and possible on yours also)?
Here's the chart. Source impedance 50Ω, load 100k.How come and there's no ringing on the 9046 (and possible on yours also)?
