Ricardus
WILL SOLDER FOR FOOD
Yes. I already asked him about this. He's just waiting for the proper enclosures.do you have any plans for a 2622 input transformer, cause I can't order any from Andrey anymore.
Any plans for UTC A-10 / A-24 copies for LA2A ?
I used the AMI/Tab-Funkenwerk UT10 and UT24 in a recent project. The work great, sound fantastic, and fit the exact mounting form factor.That would be pretty good, because used stock of those UTC transformers dried out and price are too high.
it would be great to have some high quality alternatives
Good news : ´suffices to read again UTM industries catalog & you’ll find the relevant output transformer.A-10 or A-24
All is well, then. A-10’s are pricey...
Here's the alternativeThe UTM2510 is 47€ which is not cheap but not that bad
RATIO | 1:9.13 |
MAXIMUM LEVEL 0.5 % THD at 50 Hz (40 ohm source) | +12 dBu |
PRIMARY INDUCTANCE | 6.7 H approx |
DC Resistance (primary) | 41 Ohms approx |
DC Resistance (secondary) | 2360 Ohms approx |
FREQUENCY RESPONSE 600 Ohms source 50K Ohms load. (-3 dB points) | 5Hz to 30K Hz |
It depends on if you want to pay for the sound or specificationThe sowter has totally different specs.
Igor, what transformer do you have for a passive DI box that is PCB mount?It depends on if you want to pay for the sound or specification
My point is that it's not really an alternative. To me, there are two totally different transformers. Which one is better is subjective and it depends on the application I guess.
No.Can the screws running through the center of the Neve style inductors be removed? I have low clearance on the PCBs because they are stacked one over the other like in the original units.
