matta
Hey Kam,
I thought about that too, but it still doesn't make sense... you see, I'm using plastic stand offs, BUT I took this into account and on the PSU board I have a separate ground wire running from the provided solder pad that is LINKED to the PSU mounting holes i.e CHASSIS GROUND and I took that to my ground point as the IEC inlet, and have continuity between all the chassis grounds... the AUDIO GROUNDS and CHASSIS GROUNDS are not connected at the PSU that I can see, we have done it ourseleves by taking the AUDIO GROUND of PIN2 of the O/T Meter to the CHASSIS GROUND at the Output Transformer... Igor? Any thoughts?
Matt
EDIT: Found it, the MIDDLE stand off hole on the PSU is AUDIO GROUND, the other 4 are CHASSIS GROUND, very sneaky... ok folks, be warned, you will need at least 2 conductive standoffs, one for the center post and one for one of the corner holes, by doing it at the PSU you tie the AUDIO & CHASSIS grounds together!
Matt
kambo said:this is freaky :
EDIT : Matt, i think its from PSU board... that pin 2 i told you to connect on main board is actually on same ground_plane as on main PCB, which is
also connected to PWR molex ground.... so when PSU board is not grounded properly to chases then there is a missing grounding link to output trx etc too...
i think that solves the mystery...
