Success, well kind of!
I finally finished up the 5 x 2254c boards last night, just ahead of power up I had fun matching the diodes and setting out to wire up:
I then wired up my single channel unit to test all the main boards in as it was easier to troubleshoot.
Now the completed wiring, awaiting testing (will neaten it up more when I have calibrated them and am ready to close the cases). I powered them each up, no smoke, passing audio, half the battle won!
And a nice close up of the front panel.
The problem is a LOUD hum, which I think has to do with my grounding scheme, in BYPASS the comp is as clean as a whistle, when engaged there is a loud hum, the controls all work as they should and it passes audio fine, but passes the annoying hum as well.
I'm thinking it either power supply or wiring related as it happens on all 5 boards, it could be control board related as I used the same board for testing each unit.
I've made a minute sample here, starts off with the said hum, then some audio that I mucked about with with the various controls and at the end you can hear the hum disappear as switch between bypass and engage.
2254C Audio Sample (5MB)
My grounding scheme is as follows:
IEC ground to Chassis
From that ground point I ran a wire to the solder pad on the 2254C PSU, which is linked the CHASSIS ground tab on the PCB
From the I followed the convention of the dual grounds to the main board, with the +24V and the CHASSIS ground.
Am I missing something?
Thanks in advance!
Matt
