Echo North
About 3 weeks!
onlymeeee said:The pins aren't used for anything at the moment. Just mechanical for 51X. As there's no +30V rail in a 51X, I thought if I'm gonna have to make one, I may as well make it from the -+16V to make it compatible in any lunchbox. Of course, if you wanted to bump up your 51X PSU to have a +30V rail, you could fly a wire straight in from the +30V pin. DIY.. the possibilities are endless...
onlymeeee said:The -10V rail is made on the main PCB. The only thing the ps16vto30v does is create a +30V rail.. so all you need to do is leave that out completely.
You may need to adjust a couple of resistors on the main PCB to adjust for the lower voltage into the amps.
I wouldn't put a diode as you'll lose even more voltage. A PTC fuse could be worthwile however.. Up to you really.
gunpoint recording said:onlymeeee said:The -10V rail is made on the main PCB. The only thing the ps16vto30v does is create a +30V rail.. so all you need to do is leave that out completely.
Thanks for the info. I was assuming that section of the schematic ( w/ the -10v ) was all on the converter pcb.
Since it will most likely be pretty easy to add the 30V conversion later, i want to try doing as 51x first. Igor's rev f style f76 i have built runs @ 24v and I'm very happy w/ it's performance. I will report back when i get closer in case anyone else is interested in doing as 24v/51x too.
tonycamp said:gunpoint recording said:onlymeeee said:The -10V rail is made on the main PCB. The only thing the ps16vto30v does is create a +30V rail.. so all you need to do is leave that out completely.
pardon me if i missed it, but what is the advantage of doing this?
thanx
T
TheJames said:Even though it isn't explicitly mentioned anywhere related to this project (that I've seen at least), the 8035 meters from Hairball have LED lighting in them. Tack an 820ohm resistor off that guy and fly a couple of wires to the +16v and power GND and you'll have your meter lit.
slegg said:Hi,
I have finished my first U76 Don Classics ! I love the sound to much ! But look at my measures ... I think I made a big mistake ! Isn't it ?
Slegg
Hello,slegg said:Hi Dbonin,
Thanks for your answer. I'm ok for the frequency response. But look at the Ratio !!!! There is more compression with 4:1 than other ratios. With same input signal of course.
