Thanx,,,, I expect to find two motors inside, a fan/blower motor to move air through the cooling coils, and compressor motor to cause the cooling. Since I have a complete backup unit I will swap out the motors too.The first thing I'd look at, would be the run capacitor of the motor (if there is one) It's kinda typical to replace after a decade when running daily.
Anytime I use my phone's gps,it's pretty accurate alerting me to all the speed traps... Not sure how that works.....but I'll use it even if I know where I'm going just for that... and to know how fast I'm going since my speedo is off.....I am shopping new cheap detectors and for around $50 I can get more features than the decades old Valentine.
Back in the 70s I drove a car with a broken speedometer... I don't recall getting stopped for speeding often.Anytime I use my phone's gps,it's pretty accurate alerting me to all the speed traps... Not sure how that works.....but I'll use it even if I know where I'm going just for that... and to know how fast I'm going since my speedo is off.....
Actually just grabbed one today from a scrapyard....Pretty excited about that....
JR - Your dehumidifier may be on a recall list and you can get paid to ditch it including disposal fee.Its been a bad (or good) week for entropy.... My frigidaire dehumidifier stopped working properly so it is in queue for the trash day collection. So two dehumidifiers being discarded. The trash pickers like these for the aluminum (?) inside.
My coffee drum roaster started dumping roasts early. The software expects the operator to stand there and watch it roasting. I have better things to do with 20 minutes of my life, so use timers so I can multi-task. The pre heat process typically takes 4 minutes. The roaster wants the drum to be up to starting temperature before adding the room temperature beans, for more consistent roasts. Then I reset the timer for 9 minutes so I can watch the last few minutes of the roasting and precisely stop the roast (typically at the beginning of the second crack).
This roaster has an added safety feature that sounds an alarm if the drum temperature rises too high, too quickly suggesting perhaps an empty roaster. The operator has to tell the roaster to ignore this safety alarm or it stops the roast.
In my normal pattern of roasts, roughly 1/2 pound of green beans, the roaster does not get too hot, too fast, so I don't monitor for the safety alarm. My speculation is that climate change global warming has made Hickory MS so hot that safety alarm was triggering (kidding). Since I was now out of fresh coffee, yesterday I performed a roast while I stood there watching the roaster (18 minutes I won't get back). Of course the watched roaster didn't alarm, so nothing to fix, and my coffee supply is OK.
Another entropy event, my 30 odd year old radar detector, a Valentine one, is now having boot up issues. At power up it won't stop beeping. I am not sure what to look for but I did happen to have a torx bit that fits the tiny crews holding the bottom on. After getting the chassis open, it is still not very accessible. There appears to be a cast metal waveguide inside.
This Valentine one has paid for itself several times over in 30 years of avoided radar traps. A similar replacement is now more like $675. I am shopping new cheap detectors and for around $50 I can get more features than the decades old Valentine.
The first dehumidifier was replaced free under warranty, the second one worked for over a decade without catching on fire.JR - Your dehumidifier may be on a recall list and you can get paid to ditch it including disposal fee.
Use this link- Two Million Dehumidifiers With Well-Known Brand Names Recalled Due to Fire and Burn Hazards; Manufactured by New Widetech
I'm not sure how that would help in court?I had a switch on my Porsche that would offset the speedometer -10 MPH for calibration tests so I could beat the cops in court…. Of course the statute of limitations has passed…
You could go to a dealer and get your speedometer “tested” and you could get off with a warning…I'm not sure how that would help in court?
Years ago my differential (rear end) started making a bad bearing noise. I took to the closest ford dealer and his chief mechanic said no problem, but thought he was a medical doctor (told me to watch it and bring it back in 6 months for another check up). I decided to get a second opinion from a shop that specialized in rebuilding differentials. Since they had to tear it completely down to replace the bearings, I took the opportunity to change the rear end ratio. I only made a modest change to about 3.50:1. I expected to see a speedometer error but it continued to read accurately. My speculation is that the speedo reads the ABS brakes tachometers.
Today my replacement radar detector arrived after I got home from my weekly shopping trip so no chance to test it out. To avoid a ticket I had to go old school, watching out for smokies. I saw two on the other side of the interstate while I was heading to the store, coming home I saw them both parked side by side at the regular speed trap location, scanning the return directionYou could go to a dealer and get your speedometer “tested” and you could get off with a warning…
A good friend used to get a lot of tickets, and the judge told him that he has exhausted all the classes he can take. He said "please come into my chambers after todays cases if you would". So he went in after, the Judge, through all the records from his priors, said "Lou, you are a very smart guy, from what I gather, you are an engineer and do some quite mind boggling things. Let me give you one piece of advice that may help you. When you design, be first. When you drive, be second. There is no harm in that, because someone is going to get the ticket. It just won't always be you.Today my replacement radar detector arrived after I got home from my weekly shopping trip so no chance to test it out. To avoid a ticket I had to go old school, watching out for smokies. I saw two on the other side of the interstate while I was heading to the store, coming home I saw them both parked side by side at the regular speed trap location, scanning the return direction
I was down to 75 in the slow lane... Some guy with TX plates passed me about a quarter mile before the trap but saw them and tucked in front of me.
Most of my speeding stops did not involve other drivers I could comfortably cruise behind. One time while I was driving from MS to Atlanta, on the 459 bypass around Birmingham that is really divided, with the two directions a few hundred feet apart in some places. I took a radar hit at speed so knew I was tagged, but the officer was heading in the opposite direction so had to crossover to my direction catch up to me. I figured a ticket was inevitable, so I slowed down to the speed limit and waited for the smoky to catch up to me. Just before the officer pulled up behind me, some idiot decided pass me at 20 MPH+ over the limit. It was a fairly easy call for the officer. Ticket the fast driver who was aware of his surroundings, or ticket the idiot who speeds right in front of an officer with his lights flashing?From then on, he always allowed a car to take the lead and never got another ticket...
