litespeedgreg
Member
- Joined
- Sep 11, 2017
- Messages
- 13
Hi Tim!Actually since you are going by last names I would be second hahahaha and if it were company names Campbell Transmitter
Corrected, plus noted the AKG assist.
Because i do QC myself, i have done checks myself. But than you have Telefunken who makes AK-47, makes clear marketing connection to U47, uses at best 20$ capsule , which is of the wrong construction. So what kind of QC they can make in order to compensate for the fact they are misleading people with something that has nothing to do with u47. Same goes for every company who sells edge terminated k67 (RK12), marketing connection to C12 or 251.What makes you think those companies you mentioned don’t do additional QC? Do you work for them? How do you know they don’t do frequency sweeps to weed out the capsules that don’t have the desired frequency response? They buy in large bulk at a lower cost so they can afford to reject. Unless you have first hand knowledge, you’re making assumptions.
Which is yet again based on AKG's, Neumann's work! Not picking on Tim here, but you get my point? CK12 is in public domain. Yet i totally get Tim's frustration.whether you feel strongly or not about all IP copyright, what most people find hard to swallow is large companies targeting individuals or stealing their work
The question was….how do you know these companies that source capsules don’t do additional QC? Unless you work for them, you don’t know and are spreading your assumptions.Because i do QC myself, i have done checks myself. But than you have Telefunken who makes AK-47, makes clear marketing connection to U47, uses at best 20$ capsule , which is of the wrong construction. So what kind of QC they can make in order to compensate for the fact they are misleading people with something that has nothing to do with u47. Same goes for every company who sells edge terminated k67 (RK12), marketing connection to C12 or 251.
Serious companies publish those certificates with every capsule, and you can even calibrate your own system using these. 797 audio sends every capsule out of the factory with anechoic QC graph.
Serious companies make their own capsules. Shure, Røde, Neumann, Primo, Earthworks, DPA, Tim Campbell, 797 audio. And as you see price of the capsules in even this case goes from 30$ to +++ So why would anyone go for rebranded capsule if the original manufacturer gives you all the QC you need, providing the proof of it?
i think he's just assuming they do no qc because they're bad. he's tested dozens of capsules of every brand, so he knows the variance between units. it's quite possible they do tons of qc and just suck at it.The question was….how do you know these companies that source capsules don’t do additional QC? Unless you work for them, you don’t know and are spreading your assumptions.
mind where you sell those paintings...Maybe I need to spend some time on an Italian beach painting
The answer is if 797 audio provides the company with detailed documentation of QC, there is no additional, except basic check to be done. So basing the 150$ price on QC done in US of a 30$ product is a scam.The question was….how do you know these companies that source capsules don’t do additional QC? Unless you work for them, you don’t know and are spreading your assumptions.
If you can work that fast kingkorg maybe we can join forces and make 100USD CK12 hahahaha.The answer is if 797 audio provides the company with detailed documentation of QC, there is no additional, except basic check to be done. So basing the 150$ price on QC done in US of a 30$ product is a scam.
Disclaimer, i do detailed QC in Norway with insanely high price of labour for free because it's 30 seconds worth of of work. In case of series of capsules it takes 5 seconds per capsule.
I do have a convenient setup tho.If you can work that fast kingkorg maybe we can join forces and make 100USD CK12 hahahaha.
For me the country where a capsule is produced is no issue at all!
As long as they can deliver me good quality for a reasonable price, they are my friends.
If a manufacturer in Uzbekistan today comes with a good CK12 capsule, I am willing to buy it!
Because he tested loads of capsules of the same source and compared them.
Because he is here for much longer than you and actually talks to people, and reads threads and people experiences with those capsules.
There's many info on capsule inconsistencies from those manufacturers around here.
Also he is a trustable and active member here with almost 2500 post in the forum, not a stranger with just 8 posts ever, that decided to use half of that, more 4 posts just to question him.
Gratefully no, he is an independent tester,
which is great because that way we can have an independent an unbiased test conclusion.
If he worked for any of them he would be bragging about that specific capsule, like they all do.
Because he did it himself and compared the results between capsules
Still many don't do,
Warm Audio is a great example of that.
They order in bulk from Chinese factories and don't do QC
He has first hand
