Aah, makes sense. Thanks!
/Jakob E.
/Jakob E.
kingkorg said:Well the biggest challegne would be to find a capsule that is spot on to get c800 sound.
Yes that Manley capsule is very close, but i doubt you could get closer without buying the actual sony capsule, which costs an arm and a leg.
The capsule is the most important part, then headbasket, and eventually everything else as the circuit is flat, and doesn't do much to affect the sound of that mic.
kingkorg said:Can you back up this claim with some measurements? This capsule has the same exact backplate as RK87, with some fancy tension rings which is a marketing trick seen many times before.
Luke claims it's 1 micron mylar(BS), sputtered with platinum. Even if it were true, none is the case with c800g capsule.
kingkorg said:Measurements of 1 micron mylar? Measurements of what is obviously RK87 backplate? Kidding right?
Have you tried to make a functioning diaphragm out of 1 micron mylar? Shure mics couldn't go under 2.5 microns and keep them stable, so i guess Luke has technology others don't.
Do you know of any 1 micron mylar capsules out there made by reputable manufacturers?
Should i also explain how c800 doesn't have platinum sputtered diaphragm? And what platinum and aluminium sputtered capsules have as a common issue?
All of these things are common knowledge. Just like "Peluso" capsule manufacturing model.
..you got your quote marks wrong - let me fix that for you:kingkorg said:All of these things are common knowledge. Just like "Peluso" capsule manufacturing model.
All of these things are common knowledge. Just like Peluso "capsule manufacturing" model.
gyraf said:..you got your quote marks wrong - let me fix that for you:
;D
/Jakob E.
Recording Engineer said:People tell me 0.8-micron aluminum diaphragms are without a doubt, absolutely impossible, even though Neumann did it with great success in sound in the 1950’s! You might as well be telling me that didn’t happen either.
kingkorg said:LoL!
Aluminum maybe, Nickel for sure, but metal plated mylar? Sorry, no.
gyraf said:As for SP, I'm not implying that he didn't do 3my membranes, just that 1) neither nice or stable, from the few ones I've seen on this side of the pond and 2) he emitted much BS and smokescreen about mic capsule technology
/Jakob E.
Recording Engineer said:Allen Luke worked at MicRehab.
kingkorg said:Now, you did shoot yourself in the foot by mentioning this, didn't you? This isn't something i'd like to have in my CV.
FarisElek said:All I have to say is that Luke Audio was posting anti-mask content on their Instagram last year and that personally doesn't sit well with me and their potential for BS.
