matta
Hey Guys,
Well I'm making progress!
I still have a couple questions I'm hoping for some help with.
1. I'm struggling to find a 310R resistor for the COM-MKUP stage, I assume a 300R will be fine?
2. R41 on the PCB shows 1K5, though the BOM shows 1K2, which is correct?
3. How are you guys testing your 4153 diodes for matching? Igor recommends they are matched, just wondering how you are doing so?
4. RE transformers, I'm using the Carnhill replacements for the old Marinairs, I assume T1 is the LINE INPUT and T2 is the MIC INPUT used as the interstage transformer?
5. What are the extra 'trano' PCB's for on the the control board PCB's, they have no solder sides?
6. RE both the PSU and 2N3055 Heatsinks, does one need to use a mica insulator on either or both?
7. I know that is was answered a few posts back, but RV1, the 5K trimmer, I can't find the part number used on the BOM, so will use a standard trimmer, but there seems to be an arrow pointing to the 3 on the PCB silkscreen, what is this for/indicate?
Thanks in advance!
Regards
Matt
Thanks in advance!
Regards
Matt
