TomWaterman said:Hey thanks Pete I hadn't done those yet!
What a ****. Easy miss.
The square flat caps are the very same, 47uF solid tants.
-T
ultra-alex said:and the red marked side with the longer leg is + ? never seen that one before...
also i got 2 x 1000uF/25V radials left. C4?
and 2 x 330uF/25V radials. C´´17?
thanks, alex
kambo said:check your wiring again.... and ur components.
Igor said:Signal structure is: 0db input-> -6db after input trafo-> -31db approx. after input pad (diode bridge can't handle line level),
then, current buffers (same level), interstage trafo-> -25dB. Signal comes balanced to bridge compressor,
and output amp is unbalanced. Audio comes out of phase, CV in common phase. Besides buffers are ac-coupled to transformer,
there's still CV swing which we have to distract from audio...transformer take care about this.
Interstage converts balanced signal to unbalanced, and matching impedances as well.
kambo said:syn said:I would set the trimmer to the middle position before switching on the unit.
yepalso,
for people without a scope,
keep the V around 1.8V on RV1 trimer-to-ground...
