Boss Looper RC1 $22 DC jack?
industrialarts
That would include shipping. This is the only source I found - https://griffineffects.com/parts/boss-roland-parts/boss-oem-dc-jack-pcb-mount
Anybody have any idea why they use a double normal jack on this pedal? I can't locate any schematics and have no idea what's the point. Unfortunately, the jack is broken in pieces, it's hard to decipher what's mechanically going on.
Any info or insight greatly appreciated. I searched some on the major distributor sits but nothing like it so far.
I don't know what you mean by "double normal jack"...
Those jacks have a switch in the contacts so that when you insert the plug it cuts the power from the battery.
Banzai has a huge range of jacks:
https://www.banzaimusic.com/Jacks-DC/
Ask in guitar pedals dedicated forums, you will get specific help about pedals over there:
Diystompboxes
Freestompboxes
The Boss RC2 has a DC input jack that incorporates 2 switches, so presumably this is the same on the RC1.
As you say, unlike just about every other pedal out there.
Don't think you have much choice, mate.
  • RC-2_SERVICE_NOTES.pdf
    3.4 MB
Thanks - I appreciate the suggestion to head to the pedal sites, I'll see if there's any additional info there.
Also, thanks for the service info. I really can't see the benefit of the additional switch, it seems it's mostly to keep the battery out of the choke and diode S1; seems like a lot of work for no real benefit. Plus, it's the most fragile part of the pedal and prone to breakage (obviously, or I wouldn't be posting :) ). It seems like they are not too readily available, either.
Thanks again
Following up on my own post
The part number is an HEC2392-01-150 (on the schem) and it appears to not be made any longer, from my searches on the interwebz. It's used in a bunch of Boss and Roland pedals.
I don't see a problem with just wiring pin 4-5 and using a standard jack. But I would appreciate any suggestions as to why not.
Oops, that was wrong. Maybe eliminate the trace from 3 - 4 and wire the battery directly to 3. Again, call me out if that's problematic but the part seems unavailable so I need an alternative
The problem is any substitute jack has to fit the same PCB footprint and sit in the same hole in the chassis.
Most but not all 3 pin sockets available are pretty much the same size and shape but you would need to check if you can actually fit them in the RC1 and then do the mod for the missing switch.
Alternative is to fit a chassis mounted DC socket, but these tend to be big and ugly and you would need to enlarge the hole in the pedal.
The typical 3 pin does fit but there is a gap, so that might be what if I do if the jack is truly unavailable - which I am led to believe it is. I still don't understand what they are achieving with the circuit, it's just avoiding the diode drop and the choke for the power supply. It's also used in the TU-2, the OC3 the Roland SP-202 and others, some don't even have the choke, so it's just so the battery doesn't have 0.6v drop? IDK
(Single Pedals: DD-7, OD-3, TU-2
Multi-Effects: ME-30, ME-33, ME-50, ME-80
Drum Machines: DR-202, DR-670)
TU2 schematic - no choke
A diode drop of 0.6v on a 9v battery is significant.
A 9v rechargeable battery is usually well less than 9v.
So if you powered such pedals with a 9v rechargeable battery with a 0.6v diode drop, and they only lasted for half a set, then Boss would be accused of making a stupid useless pedal.
Perhaps.
