Brian Roth
John....with "time on your hands"....does the "official" method linked in post 255 make any sense?
Bri
Bri
No? What makes you think I have time on my hands? I have stuff I should be doing right now instead of this.John....with "time on your hands"....does the "official" method linked in post 255 make any sense?
Bri
this was human error or more specifically a case of "old man dropsies". I suspect other senior forum member may recognize the affliction.
I have just ordered two new GFCI outlets.
FWIW the Leviton that I ordered is also made in China as are most such things these days.![]()
That outlet is ground bonded to my fuse box with a separate redneck DIY safety ground wire.
I roast coffee in that room but that should not release significant humidity.
In my area of Canada, about 25 years ago it was acceptable by code to put a GFCI receptacle in a bathroom with one linked outlet outside, which I still have. I have not looked at the code recently but I think that is no longer the case.I have one in my garage that is linked to another one in a bathroom in another part of the house - crazy, eh? I suspect it is because it is close to a water sprigot. Either that, or the electrician figured that is whare one might put a table saw or operate other power tools. Who knows? Still, I agree they CAN be a tad touchy.
Stringing GFCI outlets together makes it more difficult to troubleshoot which outlet caused the trip.Those CAN be fussy. I have one in my garage that is linked to another one in a bathroom in another part of the house - crazy, eh? I suspect it is because it is close to a water sprigot. Either that, or the electrician figured that is whare one might put a table saw or operate other power tools. Who knows? Still, I agree they CAN be a tad touchy.
I suspect there is a bias toward false trips and never missing fault currents.Intermittents ARE a supreme aggravation in any case.
I believe manufacturing location is much less important than design location. Lots of stuff made in China is designed elsewhere, perhaps with higher safety and performance standards, so probably no worries with your selection. This made for the US and EU are usually higher quality, and cost more, than products to be sold elsewhere, and that makes sense I guess.
I paid a little more with that hope.I think your selection will be OK. Parenthetically, Leviton dimmers are fairly RFI and EMI quiet compared to several other brands (which is matters in my amateur radio station.) They seem to be designed well.
I had an ARRL handbook when I was a kid (my dad RIP was a ham).Serving Suggestion No. 38763 --
Gee ... Ahem ... ah ... I am not so sure I would do that. Something about the NEC and domestic safety grounds springs to mind. Um ... I read books by Motorola, the Lightning Protection Institute, the ARRL, and the NEC for proper grounding of my radio station, which makes me somewhat skeptical about your red neck ground scheme. While I am NOT an engineer, I sorta, kinda suspect that is contraindicated, and maybe, not sure, contributing to the occasionally faults you experience. Perhaps a topic for review some rainy afternoon?![]()
I have been using a Hottop Drum roaster for a couple decades now. Roasting effectively cooks moisture out of the green beans. The Hottop captures the chaff and uses forced air to cool the beans in the cooling tray, to quench the roasting quickly when you have finished. Roasting 1/2 pound of coffee slightly warms up the unheated laundry room but does not appear to result in noticeable humidity. Plenty of smoke, which is why I do it in that room.I agree. The roasting process is a fairly dry operation. I forget if you have a "proper" coffee roaster machine, or employ another process ? While I usually use a dedicated roasting machine (appliance) - I sometimes use a countertop convection oven (toaster oven) at its highest heat. The only down side to this latter method is the aggravating amouint of "chaff" that burns off and flies about the roasting room afterward. I carefully take the beans outside to cool and use a photo hand blower to recycle them in the outer environment.
My experience with cheap GFCI outlets has always involved random false trips, but they are generally few and far between. The recent interruptions to my overnight dishwashing may reveal a new trip pattern. If it isn't the GFCI outlet then the next likely suspect would be my dishwasher that isn't very old. I have also had issues with this one GFCI outlet not coming up energized after power outages so my bet is that it is the guilty party.GOOD LUCK sorting out your circuit breaker conundrum. I hope it is as easy as replacing the outlets. / James
burr grinders do make a difference...(subtle but real).My latest quasi-entropic crisis involved my beloved Baratza coffee grinder.
i buy my green coffee from Sweet Marias outside of SF (Oakland) the original hub for imported coffee from around the world. I have ocassionally been tempted by cheap greens from other vendors but they never live up to the quality Sweet Marias consistently delivers.A chard of broken plastic in a bag of commercially roasted beans clogged the burrs, causing it to seize and grind to a sudden halt, blowing an internal fuse to boot. It required some effort (OK, time and patience) to dismantle the beast and remove the debris and replace the internal fuse. The offending source was a bag of "Sputnik Coffee" from Chicago, acquired on the cheap at a local closeout outlet. Not such a good bargain, after all. I contacted the company which was very responsive and treated the incident in an apporiately serious manner, accepting my suggestion it might examine its roasting and packing process and machinery for broken bits that could contaminate the coffee and cause serious liability from foreign matter in their product. Fortunately, the grinder operates as new, after a thorough cleaning and reassembly. Proof I should stick to my own beans.
Parenthetically, the company offered me a replacement bag of beans ... which I declined. James
I have to ask the signifigance of the blue stripe on the flag ,
hadnt seen it before ,
Should there be any expectation of consistency with the gauges? Rain should be reasonably random in hitting the 2 gauges. The fact that they measure in opposite directions is actually somewhat of an indication of randomness isn't it? Maybe averaging the 2 may be a more accurate indication of the actual rainfall.Now my dueling rain gauges are disagreeing in different directions. Now my fancy freeze proof rain gauge is measuring 3 1/2" and the low tech plastic rain gauge only 2 1/2". I have a new theory for that, the plastic rain gauge was tilted back at an angle to make it easier to read. In theory that would reduce the cross sectional area of the rain gauge opening accepting in less rain. My gut is not comfortable with that explanation, but it's all I gut.
For now I will believe the rain gauge with the highest reading.
It must be the the fancy freeze resistant rain gauge that is off. The other one, being cheap, can't afford to be wrong! ; )The 1" discrepancy is difficult to explain for two gauges located inches apart in my yard.
After the last major rain they pretty much agreed.It must be the the fancy freeze resistant rain gauge that is off. The other one, being cheap, can't afford to be wrong! ; )
