dmnieto
ruairioflaherty said:Well done on going from schematic to proto so quickly.
As a mastering engineer the main reason I couldn't use this build is ergonomics. For me the space between knobs and the 1dB steps would rule it out for me. I realize that this is much more likely to be a bus EQ for a space challenged engineer/mixer rather than a purist mastering tool.
Again well done on dealing with the noise issue so quickly. Absolute levels of noise are only part of the discussion, the character of the noise is equally important. For example my Pendulum OCL2 is very noisey but mostly at very low frequencies which is very tolerable for my work.
Ergonomics is without a doubt the biggest issue.
The steps, actually not so much, let me explain. It is not featured in the prototype, but the step height is solely defined by the value of the resistor in R82. For the 500 version I plan in adding another control switch. That would allow to make the EQ steps either 0.5dB , 1dB or 2dB.
Coming back to ergonomics, my wife is apprenticed to a mastering engineer in the bay area and I designed this EQ for her. She is 5'1" and for her space matters and she has no problem in using the knobs.
For the version that I am building for her mentor. I am racking this ******* and using http://www.ebay.com/itm/New-2-Pole-23-Step-Rotary-Switch-Attenuator-Volume-Control-Pot-Potentiometer-DIY-/221398438804?pt=US_Amplifier_Parts_Components&hash=item338c601394 this attenuators to provide either +/-3.0, or +/- 6.0 with 0.25dB or 0.5dB steps.
Noise is very low now... it has a white noise floor of EIN -135dB with a flicker noise of <500nV/Hz^0.5.
I really enjoy that I have managed to put it in a 500 series envelope, but I agree that it is much more useful when it is racked. That is basically the reason the frequency switches are on the PCB while the gain control and other switches only have header connectors.
I wanted to make it fit in a single space so the entire pair would fit in 2 space on a 500 series. At the same time, you can make this fit on a 1U space as well. But if you have a 1U space you probably won't need to deal with diminutive SMT parts.
