vintagelove
- Joined
- Oct 26, 2013
- Messages
- 150
Obviously I can't tell you the exact cause of the improved transient response, but I can tell you it's there in comparing it to the same capsule with the traditional construction (and being very familiar with countless other mics). Perhaps they did use a thinner diaphragm as well?Not sure how this could be the case. Transient response is determined by diaphragm mass. It is also inseparable from frequency response. This is physics, even though the marketing often advertises something else. The mass of the diaphragm is not affected by the miniscule amount of gold. The only way this could be the true is if they used significantly thinner diaphragm material. Which could be the case. SDC doesn't necessarily have better transient response, this is again dependent on other parameters. Transient response is very difficult to asses without doing objective measurements. Even some modern ribbon mics have better transient response than some older SDCs.
Images like this are spread throughout the interned, and autors live in delusion they show transient response. In reality they show effect of several different things, that may or not have something to do with transient response.
That being said, published FR of JZ mics do show excellent transient response presuming they are acurate. I am pretty sure golden drop technology is not the sole reason for this.
I also applaud to JZ for taking the effort to innovate.
I just went to see if I could find what you mentioned they published, and I came upon the following. Truthfully it's out of my depth to call BS or not, but I'd like to hear your opinion on it either way.
"microdots help avoiding membrane resonance frequency waves and because they are slightly lighter they have better high frequency transient response than the classic sputtering"
On the JZ site it says the capsules diaphragm is lighter, but I don't know if they're claiming that is just because of the dots, or they actually changed it's construction.
PS, I always have the nagging desire to pull the capsules from this pair and use them to build a nice set of tube mics... I have some really nice mics already, but... I can't help wondering what they'd sound like....
