berkleystudios
Hi guys,
I was just about do doing some finishing touches on my cheaper build and I decided I would change and try and go all out.
I have been doing a lot of research and it looks as though is is more of a 175 than a 176. because of not being able to change ratios, which if following the original 175 would be a 12:1 compression ratio. the 176 used a multi tap output transformer to achieve other ratios.
I am doing more research to see if I can implement a ratio change in my build with a multi tap transformer. I am going to be looking more into this as I would really like to have something like a 4:1 and 12:1 or 20:1 compressor/limiter modes
I will also be trying out other tubes if my new matched 6bc8's dont work out, looking at also 6BQ7A's as a possible alternative.
swapping out my current edcors for possibly cinemags ( anybody have a price on those?) I know I want it on the interstage, still debating what I want on the input, The output will be decided when I figure out If i can really implement the compression ratios into this design.
I think I will put in a GAR1731 on the inputs and move 2 of Abes dip8 2520s to the sidechains. I would really like to get rid of the TLO74, or at least upgrade it to something better. possibly even discrete.
thinking about a variable high pass filter as well.... but IDK if I will have room on the front panel because Im adding big simpson meters, 4 large dakaware style knobs on a 3U case... might be kinda tight, knew I should have gotten the 4U....
so quick list run down of the new plan/ hopes and dreams/already done
- All discrete (if possible) (6) 2520,(2) Gar1731, (2) unknown dual discrete opamp
- cinemag inputs and interstage, unknown multi-tap output for different compression ratios
- add ratio switch on front panel
- 5M release pot for longer release times
- Orange drop in C5/C52 (done)
- Add VU meter drivers and front panel switches for input-GR-output
- remove threshold trimmer/ jumper OR add threshold pot on Front (depends on room up front and calibration difficulties
- remove desser
- add variable HPF, (possibly), play with new cap values for best filter slope
- add high quality Input and output pots. not sure of what values I will go with...
- tube swap till best option is found
kinda bummed about the reports that the rest of yall have... hopefully this thing sounds pretty cool by the time im done.
Adam
- remove desser
Adam
