No secrets here, I used transparent foil for overhead projectors.
Edward said:Do I ground the PSU pcb from pin 4, which is the CT? Is that the only connection to ground needed from the pcbs?
abechap024 said:Edward said:Do I ground the PSU pcb from pin 4, which is the CT? Is that the only connection to ground needed from the pcbs?
What do you mean exactly? You don't need to add anything. The only connection you will need to "ground" (connecting the audio ground to chassis ground) will be at one of the input XLRs (you have all the pin 1s of all your xlrs connected directly to chassis at the xr right? ) and you only connect any of the XLR pin 1s at ONE and only one xlr to the respective pin 1 on the pcb.
Hope that helps
Abe
Edward said:abechap024 said:Edward said:Do I ground the PSU pcb from pin 4, which is the CT? Is that the only connection to ground needed from the pcbs?
Hope that helps
Abe
I was reading the rev 1 thread and somebody was writing about that... From now on I will try to stick to the plan and stop trying to figure out stuff by my own as it usually turns out horribly wrong. Thanks again.
earl said:Hey Abe 1 channel of sonic bliss complete... squishy aggression. Sounds of glory. Thanks for making this truly unique project available. Using lundahl's and 2520's.
sedit1 said:Hi!
I'm having a problem with my power transformer(s) 230v
I have 2x25vac and 2x15vac toroids.
I've connected one 24vac secondary to 15vac secondaries witch are connected in series and I get 260vac am I doing something completely wrong here?
abechap024 said:sedit1 said:Hi!
Do you have the 15V transformer the one that is connected to the mains? Also maybe measure each transformer to be sure of the voltage they are putting out.
abechap024 said:Well if you have the 24V connected to mains, and then connect that to the 15V transformer your going to get more that 230V on the output. Which for the G9 is fine, but this project you only want 120V or so.
When you apply 15V to the secondary side of the 15V transformer you will get the spec'ed 230V on the primaries. What happens when you increase the voltage on the secondaries? The voltage will raise faster on the primaries. So if you apply 24Vs to the 15v transformer its no big surprise you are getting more than 230v right?
(I know the whole "secondary" and "primary" is a little confusing because we are flipping the transformer around and essentially using the primary and the secondary etc etc, don't get confused its all the same to the power transformer!)
So then applying the same logic to the 24V transformer. When you apply roughly 24V on the secondarys of the transformer you get roughly 230V on the output, right? Since we want a little more than half that voltage, we'll apply a little more than half that on the secondaries. Wait, you still have that 15V transformer right? That will be perfect.
Make sense?
230::15::24::150ish
BE SAFE!
sedit1 said:Does this make any sence or would it be just easiest to buy 230->115vac toroid and also use 2x18vac for 18v?
ethervalve said:Hi all,
Just got mine together and turned it on, psu voltages are ok but I need to do a bit of troubleshooting.
I'm a little confused by one thing in the schematic (incidentally, is the Rev1 schematic still OK to follow for Rev2 boards?):
when using the IC input option (which I'm doing), do I just jumper the OPT_1 and OPT_2 pads? Or do any of the transformer pads require bridging?
Thanks in advance
