the only thing worse than being a home owner is renting.Some days I hate being a homeowner....
not expecting anything that photogenic....Looking forward to pics....
my websites got crossed when I was messaging...lolnot expecting anything that photogenic....
Here's your pix Scott...Some days I hate being a homeowner....
Really??They advised using some silicone caulk under the top drain rim and all I had handy was a several years old dried up tube. I cut it open and scraped out enough to make a seal.
Really??
I've always rolled a snake of plumber's putty and wrapped/stuck it under the drain (flange?)..As you tighten everything down, it oozes out the sides and you just pull it off and clean a bit. Some kits come with gaskets now but I never had luck with them....
Cool.... glad you got it working.....
Surely you looked ? it'll leak under the sink there if water gets past... I did look at the terry love forum real quick and there does seem to be a school of thought for using silicone too... I've definitely used it in shower drains just never had issues with using putty with sink drains...If water leaks there where is it going to go? down into the drain?
A couple of years ago one of my friends/clients was telling me she was downstairs and water started coming out from one of the recessed lights in the ceiling. Turns out the cleaning lady upstairs had started filling the glass vessel sink, for whatever reason, and got distracted for a really long time....In the lasts several decades I have never had the sink overflow. I just did it on purpose one time to confirm that it works
Embarrassed to say but I've always replaced little carbs since they're so cheap but after youtubing a little the last time I had issues with getting my mower going, it was exciting to see how useful a piece of wire brush was for cleaning out all the ports and jets.... never knew the bowl bolt was one of those areas either....I'd seen this before, a stuck carburetor float valve
Looks like you still have power I'm guessing? Hard to tell what that storm is doing there......in response to Hurricane Francine
I lost power sometime around 5am. I did not wake up until hours later.Looks like you still have power I'm guessing? Hard to tell what that storm is doing there......
must be nice having that metal roof...I was outside checking on fallen limbs and the wind picked up again so I moved inside, out from under all the trees.
I don't know that the metal roof adds much structural integrity, but at least the shingles won't blow off in the wind.must be nice having that metal roof...
I'd feel safer in your home than this straw....at least we're block on the bottom....with messed up crumbly mortar joints from the incompetent contractors.....
