abechap024
Esoterimix said:I'd venture to guess that the SP3T switch needs to be on/on/on... I was looking for some yesterday for this project. I'm a bit confused on the input pad as far as what needs to be jumpered to what if I don't want an input pad? If anyone has a second, I would really appreciate a hand.... I'm assuming a couple of jumper shunts will do the trick, hopefully?
The switch needs to be on/off/on at least on how I've imagined it...there is always a small value cap in series with the sidechain, so with no switch enabled the sidechain defaults to "de-esser" Then you add a a capacitor with the switch, and when you flick the switch in the other setting you add a different capacitor. You can tune them to whatever frequency you choose.
I just found I liked the input pad, you don't have to have an input pad if you don't want, obviously, but the originals and the 176 retro both have one. and it seems to give a nice gain adjustment, but hey make it your own! Test it, mess with it
Where to put it is in the documentation on the first post.
