abechap024
tazwolf said:Has anyone found a supply of 45 volt bipolar electrolytics with a 2,5 mm lead spacing?
/taz
You mean the 47uF 25v? I've never heard of 45volt caps..
/taz
abechap024 said:tazwolf said:Has anyone found a supply of 45 volt bipolar electrolytics with a 2,5 mm lead spacing?
/taz
ilfungo said:Thanks Abe for all answers....
sorry only for confirmation
with Output transformer I ca remove:
R38-39-40-41-42-43-44-45-46-47-48-49-50
C15-16-17-18 and 5532
Correct?
e.oelberg said:abe !
sorry to ask again: the bd140 and 139 where does the silver side go, or where does the emitter go.
I#m sure there is a standard for the silkscreen I just don't know it.
nicholas
berkleystudios said:my 139 and 140's dont fit in through the holes. which ones have yall ordered?
bastrika said:Hi , i plan tu use LL1540 trafos, i've noticed ground/shield are not routed to anywhere.
Are they routed in previous revisions to take out hum problems ?
prh said:Abe, could we get a schematic for the API op-amp?
On the DOA boards, what is the orientation of the diodes?
Cheers, Paul
abechap024 said:The schematic is identical to this one:
http://www.acsoundstudio.com/manuals/BUILD_MANUAL_A_OPTIMIZED.pdf
prh said:Abe (or anyone),
On the DOA boards, which transistors correspond to Q1 and Q2 (BC550, which need to be matched)?
Cheers, Paul
