Really would be not bad thing : )If no gerber, I scan PCB top and bottom (and sometimes even print out) before populating. Can come in handy later. Definitely don't have rev4 boards here though.
+ 1 here ,Really would be not bad thing : )
also for the build manual that the link do not work ,
posted on first page of this thread :
www.acsoundstudio.com/manuals/PRR_REV4_BUILD_MANUAL2.pdf
someone have a copy ?
much thanks in advance !
There are older PRR 176 threads that should cover these questions.Anyone recall if/what the errors might have been on the first revision #1 of the PRR_176 by ACSound. I'm starting a build on one soon and wanted to find out if anyone still had this. If I recall the very first edition had some things that needed changed and jumpered to get it going smoothly?
That's strange... it looks like the threads were actually deleted... why...?There were, but everything for Rev 1 points to this link which is dead.
https://groupdiy.com/threads/44586/
I've happened across this several times with different topics...That's strange... it looks like the threads were actually deleted... why...?
One IC audio path (on input?) not connecting, and the entire PSU was said to be noisy.Anyone recall if/what the errors might have been on the first revision #1 of the PRR_176 by ACSound
If you look at the URL on this thread for instance, the title is in the adress. I think that's from the forum software swap (xenforo). Before you'd see URL:s like above. So if the thread is still there, it'll have a new URL with the thread title in it.There were, but everything for Rev 1 points to this link which is dead.
Oh believe me I've tried every option I can think of in a loop to locate that missing thread. Searching forums with every variation of the project name, searching title or old link in the wayback machine, webspidering the forum with alternate portions of the link address to see if it pops up that way, still searching.If you look at the URL on this thread for instance, the title is in the adress. I think that's from the forum software swap (xenforo). Before you'd see URL:s like above. So if the thread is still there, it'll have a new URL with the thread title in it.
I can't remember. But will be sure to point it out when I come across one again. It's definitely usually older stuff. There's that error and then there's one where you don't have permission to view this thread or something....What other topics did you see disappear?
https://groupdiy.com/threads/44586/I can't remember. But will be sure to point it out when I come across one again. It's definitely usually older stuff. There's that error and then there's one where you don't have permission to view this thread or something....
Is there or was there ever a PRR 176 ver1 thread?
I get that link when trying to come to the link from diy wiki page. Is that a link to the thread from another thread here or from other website?
I've found it on both external sites and here.I get that link when trying to come to the link from diy wiki page. Is that a link to the thread from another thread here or from other website?
