PRR-176 REV 4 Build Thread ***Manual up!***1/16/14 - (chk 1st post)
A member sent kindly set me the BOM and it does show that the NP marked Caps can be polarized.
All except the TX output Cap.
I plan on running the Cinemag output transformers and switch between TX and Non Tx output. Switched on the back.
Looks like I'll need to order 2 NP caps.
Is this the BOM?? Why isn't there info in the tech docs section I wonder???
Edit...I see it's an older version..... Can we upload the documents in the tech docs???? seems like there is still much interest in this..
  • prr_176_bom_1.pdf
    211.7 KB
Thanks for link scott2000
Doa part list finded!!!
https://buildbutler.org/build/a-style-2520-dip8#_BD139
Sorry
I want to use ABE doa in API preamp...
if I remember correctly the DOA pins need to be inverted
need to be solder on the other side?
could this DOA work at +/-24v?
thanks!
scott2000 said:
What is it you need? All of the pdf files (not links) are attached above. If there's something you are not able to get from the files above, let someone know and maybe it can be uploaded......
thanks scott2000 !!!
got the 7 attached above ,
unfortunately not the same for the following 2
https://buildbutler.org/build/prr-176-rev4-main-board#_47uF-NP
