ding
kakumei47 said:Or just build Abes if they match.
That was my plan as soon as a BOM is available for it. Anyone hear any news on that front?
To be honest, I am beginning to lose patience waiting for the schematic and BOM.ding said:kakumei47 said:Or just build Abes if they match.
berkleystudios said:referencing the rev4 board against the rev 1 and 2 BOM the output pot value has changed from 100k to 10k. will 100k still work for this? I only ask because I had already made stepped input and output switches before I received the boards
abechap024 said:Updated Docs!
Sorry on my end, and thanks for the patience everyone.
Also, shoot me a message or PM if you didn't get any of the 2520 opamp PCBs. That was a stupid mistake on my part. I looked at the pinout a million times and yea. I know this is a big bummer to some people, luckly I made the same mistake twice with the API opamp PCBs I have so they should just drop in.
Note: It is very possible to use any discrete opamp with the revision 4 PCBs you would just need to install them from the bottom of the board, you wouldn't be able to show them off, but they still should sound awesome.
Also the API opamp PCBs I included as a "bonus" with most all the pcbs (let me know if you didn't get some and I'll send some your way) they can be used in other projects they will just have to be inverted when installed, which actually might be a good thing.
The input and ouput potentiometers are 10k
This revision has less hiss and lower distortion than the others. I think you will find this more pleasing. A little smoother.
We changed some resistor values from the Silkscreen. a 100k resistor dealing with the input section potentiometer (makes the taper more even) changed it to a 2k.
Changed the 3k3 resistors that feed the CV to the tubes to 6k8 as the original 176 schematic and after many listening and tweaking tests, seems to help the overall gain staging.
You can get rid of the 5k threshold pot and just jumper it, of course you can leave it in and adjust the threshold to how you want it...its a very interesting adjustment it can change the tone and gain structure. I found just jumping it gave good results and simplified the calibration.
Also there are 3 little wire jumpers that need to be added on the PCB board itself. As shown on the wiring guide
I'll be adding more as it comes.
ilfungo said:Sorry
in-out-attack-release pot, are lin o log?
ding said:Is using the OPA2604 on U14,U15,U31,U32 a waste of money or will it make a difference? Its 12mA vs 16mA for the NE5532P.
shot said:Abe, thank you for chiming in and posting those documents. Awesome!!
I have few questions before I start ordering components.
1) You mention that release pot can be 5M for long release. What about using standard 1M pot in series with 1M switchable resistor? Would that be usefull?
2) Are all the 47uF lytics in the power circuit as you state in your bom? So I shouldn't care if they are audio grade and I can go with whatever model?
3) Put input pad on a switch - does that make sense?
sure! They would be pretty large though. And you don't have to use bi-polar. Bi-polar seem to sound better, but A LOT of really great sounding things use polarized in the signal path, so use whatever you want.4) Few caps are NP - thats nonpolarized, right? So I could use (wima) film caps, right?
5) In europe, with our 230V mains, it's hard to find power transformer with 110+18+18 secondary. So i have to order custom made one. What amp ratings should I specify for those secondary windings?
