Hi Abe!!!ilfungo said:sorry
and the other 50mA is sufficient for all the rest?
abechap024 said:Ok. The BOM pdf now has the schematics attached.
ding said:What are the 8 mounting pins for on middle of the DOA's? Do these need to get put on also? Again I also want to double check that my 1mA meters will work like in Rev2. Also I noticed on the BOM that 4 of those 1000uf caps should be 50v as per the silkscreen and not 25v, is this correct?
I just chose 3k but I would be interested in the answer just for curiosities sake.mrdarwin said:about 2520 DOAs...
what does mean "3k-5k" resistor?
3k? 5k? 4k? which determines this resistor value?
ilfungo said:If output transformer is used, which components I can omit?
and old question:
50ma is ok for all ic's?
