[/quote]
Actually, I'm pretty sure you all can just replace the "1k 2watt" resistors in the power supply with "5k 2 watt" (actually 4K3 seems like a better value after simulating it) resistors and be fine using 240V instead of 120V...I've done the calculations and nothing *should* blow up. Some one try it for me, or correct me if this is a mistake!! That would be A LOT easier for you guys, us 120V can't have all the fun.
Also for reference, it will be about 40ma of current total for the tubes.
[/quote]
Can European DIYers use two toroidal transformers?
[/quote]
